Is This Normal????
Old Sep 7, 2000 | 10:15 AM
walexa's Avatar
I have a 2001 Xplorer 400, and once it is completely warmed up, there's a light squeaking noise coming from the front of the engine. Sounds like it may even be coming from the oil pump area. It goes away if you give it a little gas, but I'm stumped as to what it could be. Thanks for your help in advance.
Waylan
Old Sep 7, 2000 | 10:28 AM
ChopperBill's Avatar
Could it be the exhaust pipe connection? Springs or where it connects to the manifold? Had a machine that one of the springs was hooked to the wrong place and the pipe would rub the frame.
Old Sep 7, 2000 | 10:47 AM
gregsims's Avatar
Walexa,
My new SP500 was making a similar noise. It would go away when i revved the bike. The day after I first noticed it, I raced Tazgrizz a few times then noticed coolant dripping from the weep hole in the water pump. I am not familiar with your bike or if it even has a water pump. I was told that the cooling system has some leftover teflon tape from the factory that made the seal go out.
I don't know if I believe that but the flushed the system and replaced the seal and I have been problem free since.
Greg
Old Sep 7, 2000 | 07:51 PM
zionalbino's Avatar
My 2000 325 Mag 4x4 does the same thing...maddening, isn't it? I haven't been able to pin it down but you've described it perfectly.
I share your pain.
Zion
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
exmotocrosser
Sep 26, 2015 08:18 AM
alzgarvin
Sep 11, 2015 08:53 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
