Sloppy swingarm
Old Dec 2, 2004 | 10:07 AM
gwyette's Avatar
Default Sloppy swingarm
I have a 1997 Explorer 400. February past I had to dissamble quite a few bits and pieces to diagnose a problem with the swingarm. It was sloppy - moving left and right. On a chain driven quad this also results in an inability to keep the chain properly tensioned. Once the swingarm was removed I discovered that the mounting points on the frame had worn. These turn out to be a pair of washers which are welded to the frame of the quad. The swingarm bolts had worn elongated holes in the washers. I ground away the welding holding them washers in place, installed two replacement washers and reassembled the quad. Yesterday, I felt the rear end moving again and when i parked it I could grab the rear bumper and see noticable play in the swingarm mounting area again. This is after about 700 miles. Does anyone out there have a solution for this problem or has anyone experienced this situation before ? (This quad now has about 5600 miles showing.)
Old Dec 2, 2004 | 11:41 AM
braveops's Avatar
sorry x2 the thread
Old Dec 2, 2004 | 11:51 AM
braveops's Avatar
one of two things 1 weld broke 2 end of the swing arm could be broke where the bushing sits in? as i have heard of this happening i had to weld washer in on mine to
Old Dec 2, 2004 | 02:24 PM
gwyette's Avatar
Thanks Braveops ! The welding has indeed broken.
STLyamwar
Jul 25, 2020 04:44 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
95wolv
Jul 21, 2015 12:25 PM
Dabears1983
Jun 23, 2015 04:59 AM
