Straight Pipe VS silencer
I am sure this question has been asked before, but:
Is a straight, smooth pipe faster on the top end than a silencer?
For example, if you took the silencer off and added a pipe extender, would you develop more HP at the top?
Originally posted by: MasterRaptor
I am sure this question has been asked before, but:Is a straight, smooth pipe faster on the top end than a silencer?For example, if you took the silencer off and added a pipe extender, would you develop more HP at the top?
So, what you are saying, is that silencers and head pipes are designed together. And, they need to be properly matched up to get the best power. Correct?
And the logic continues.....
So, if I take off my silencer and extend my pipe and rejet using a dyno, there is no way I will get more HP.
Man, you'd think with the free flow, you could get more HP.
Are there any technical people out there that know why this happens?
And the logic continues.....So, if I take off my silencer and extend my pipe and rejet using a dyno, there is no way I will get more HP.Man, you'd think with the free flow, you could get more HP.Are there any technical people out there that know why this happens?
I have heard that. They try to time the shock wave such that it the first wave creates a vacuum that pulls the exhaust gasses out of the cylinder.
But, the frequency of the shock waves is contantly changing with engine rpm, so, if the lenghs of the pipe are set for this phenomenon, then it would only happen at a certain RPM range.
Don't you think that these pipe desingers are just a bunch of guys tinkering in the garage, fit the pipe to the bike, and see what the dyno reads?
Or are they these highly talented acoustical engineers that set up data aquisition systems run tests, tweak pipe lengths, change jetting to produce the most HP?
mrtidy
Feb 3, 2016 05:00 PM
greg86hd
Sep 16, 2015 12:32 AM
