Wiseco Big Bore ?
Old Dec 6, 2004 | 06:22 PM
JOEBALLZ's Avatar
Default Wiseco Big Bore ?
I have a 2001 400EX and iam looking into doing the Wiseco 440CC kit and hot cam. I looked on ebay and i saw 2 different compression types 12.5:1 and 11:1. Which is better and which stage cam 1 or 2? I hear the stage 1 is bad with bore is this true. any help will be appreciated!!! Thanks.
Old Dec 6, 2004 | 07:00 PM
polarsport500's Avatar
id recommend the 11:1 ratio because u can still use 93 octane... wiht the 12.5:1 youll have to use racing gas so if u dont mind then go for it. and with the bore the stage 2 works wonders
Old Dec 6, 2004 | 10:03 PM
sandman99ex's Avatar
if u get the bigbore kit id recomand that u get a new crank so u dont broke ur quad in the first couple of hours u ride it
Old Dec 7, 2004 | 03:51 AM
cals400ex's Avatar
the stock crank is fine. with 12:1, you may want a heavy duty rod. i run a 11:1 on a stock rod and i haven't had a problem yet. with higher than 11:1 you will also want to use race gas along with heavy duty head studs
STLyamwar
Jul 25, 2020 04:44 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
