Oil Change On Raptor
Old Dec 7, 2004 | 02:39 PM
Mattic's Avatar
Default Oil Change On Raptor
I apologize in advance for such a silly question. But... When I bought my 03 rappy all I got was the bike. No manual, etc. Where do I drain the oil from? I've searched and found the proper procedure once it's drained to refill. I just want to make sure to drain it properly. Thanks in advance.
Old Dec 7, 2004 | 02:44 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
remove the plug on the bottom of the oil tank and drain the tank
remove the large plug on the left/bottom/rear of the motor(behind/under the shifter) and drain the crankcase
change the filter
Old Dec 7, 2004 | 02:49 PM
Bing's Avatar
Super Quad Patrol
it takes aprox 2 quarts of oil
fill the tank as much as possible,,,then start the bike to run the oil into the motor and lines
finish filling the tank with oil
Old Dec 7, 2004 | 02:50 PM
maddog56's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 7, 2004 | 02:53 PM
garyc660R's Avatar
In adding to Bings good info, don't overtorque the oil tank reservior because it cracks easily. Don't try to add the total 2.5 quarts at one time either....you will wind up getting oil everywhere.
Old Dec 7, 2004 | 03:25 PM
RaptorOwner's Avatar
Also, just my .02 worth. I quit using the oil plug on the tank because of that same problem. I undo the line next to the case plug and drain it all from the same location. That way you dont have the mess all over the frame and hard to get oil drain plug on the tank. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 7, 2004 | 03:32 PM
Bing's Avatar
Super Quad Patrol
hey thats a neat idea
Old Dec 7, 2004 | 04:12 PM
garyc660R's Avatar
Originally posted by: garyc660RIn adding to Bings good info, don't overtorque the oil tank reservior because it cracks easily. Don't try to add the total 2.5 quarts at one time either....you will wind up getting oil everywhere.
My thoughts exactly. No worries of ever cracking the tank when changing oil. An o ring sels the piece to the case anyway.
Old Dec 7, 2004 | 06:46 PM
Roach007's Avatar
Hey I learn something new everytime I come on here.
The whole time I have owned my 01 Raptor this past week-end I found another grease zirk on the swing-arm pivot arm. I knew of the upper and lower, then I saw the one located right behind the engine that looks like a bolt but has a grease fitting on the end of it.
Old Dec 7, 2004 | 06:49 PM
Thank you, Thank you very much..... [img]i/expressions/face-icon-small-wink.gif[/img]
Kaleb_00
Jun 1, 2016 09:15 AM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
