warrior K&N air filter jetting
Old Dec 8, 2004 | 09:54 AM
bullgator's Avatar
Default warrior K&N air filter jetting
I have a 02 warrior with a cobra pipe and just got a K&N air filter will I need to put in a jet kit I well be running it with the air box lid on
Old Dec 8, 2004 | 12:26 PM
toy4rox's Avatar
i would think that if you are adding air { k&n } getting rid of burnt gas faster { pipe } then you need to add more gas..just a thought. i did mine but the day i went out to test it the piston fell apart.. not becouse of the mods but the rod berings were shot and that coused the piston skirt to go when i took it apart 1/2 the rod berings were gone and a lot of meatle powder in the case
Old Dec 8, 2004 | 04:11 PM
rotty150's Avatar
It will run fine the way it is but you could go up 5 on your jets and see if you like that better?
Old Dec 8, 2004 | 04:35 PM
86LT250RFatty's Avatar
Deffinatly Re-jet. Befor you even run it, i would go up 3 sizes and then tune it from their. Maybee even 5. Its better to start out rich then lean..good luck.
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
