Car Stereos...
Old Dec 8, 2004 | 06:08 PM
WheelieKing's Avatar
Default Car Stereos...
I don't know alot about Car stereos but I want a good sytem for my truck, Its a regular cab. My buddy has a subwoofer in his trunk, I want Base like in his car but in my truck is this possible? That Sub in his car wouldn't fit in my truck unless I put it on the passenger seat. Any help that could give me a clue what to do about this would be helpful, thanks.
Old Dec 8, 2004 | 08:41 PM
Kawi650's Avatar
listen to cbc radio one and you will not need a subwoofer period[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 8, 2004 | 08:54 PM
dragracer789's Avatar
Ya you can get up to a 12 inch sub to fit behind your seat. You will just need to build a custom box for it.
Old Dec 8, 2004 | 08:58 PM
FsT4WrD's Avatar
Really need to know what kind of truck it is. Its not the size of sub thats produces the bass, its the box.
S-10 can fit 4 10'' subs behind the seat and blow away any hatch back bandpass 12
4 12's can fit behind almost any full size truck as long as the box is built correctly and the subs can handle small qube space.
I have seen a toyota tacoma reg cab that had 4 7x10's blow away 2 RF 12's in a db drag.
Old Dec 8, 2004 | 09:28 PM
Its a 1990 F250, it deosn't look like it has much room behind the seat, should I go to a car stereo dealership and have them tell me what they think?
Old Dec 8, 2004 | 09:30 PM
Tommorow i'll measure how much room I have behind the seat...
Old Dec 8, 2004 | 10:18 PM
alleycat's Avatar
A few years back(5 years ago) I had a 1990 ford f-150 regular cab, with complete kenwood system. Not the best by any means. At the time I had 2 box speakers. Each box contained a 10 inch sub, 3 inch mid and a 1 inch tweeter. It fit beautifully behind the seat. Both boxes were ported and it sounded great. Also had a 320 watt amp and a six pack cd changer. all fit behind the seat. Amp mounted on back wall of cab under window between the speakers. Changer mounted just behind driver side seat. I would imagine they still make those box speakers specifically for trucks.
Old Dec 9, 2004 | 12:55 AM
pendejo's Avatar
I would definitely talk to a local shop for opinions. It's really hard to build a box to fit behind the seat of a standard cab and still have full forward and back movement of the seat. I put 2 12's in the back of my Mazda B-2200 in a custom box. All I did was make a template that went from 2 inch below the seat, down to the floor and followed the contour of the tranny "hump"(that doesn't sound right, oh well) then copied it so I had two templates and put my seat back all the way. Now with the original template taped to the rear wall, run the second parallel to the seatback, but leave at least 1/2 inch between them(I taped 4 half inch wide pieces of wood to the seat and then taped the template to those) now, you should be getting an idea of what it will look like, you just need to close in the sides, top, and bottom. Then make the cutout's for the woofers, and decide if you want to port it or keep it sealed. If you do it yourself, search google for info on how to properly build an enclosure and how to port it(believe it or not, you can't just cut holes in it!) Well good luck, what do you plan on using for woofers and amp? I might have some stuff for sale, if interested.
Old Dec 9, 2004 | 01:05 AM
pendejo's Avatar
For your info, just because an amp says it will put out 1000 watts, doesn't mean it's true. I have an Orion 225 HCCA that is rated at 25 watts per channel at four ohms, but it is quarter ohm stable and(lower the ohms, more power) so it's possible to extract 600 watts(or more) from it. Keep that in mind, make sure you are eductaed about what you are buying from a reputable source. When I first got into car stereo's, I had to get some help from a local shop to install my first amp, and when I pulled it out, they said it wouldn't work( because I didn't buy from them) so I took it somewhere else, and they taught me everything I ever wanted to know about anything related to car audio equipment. Talk to Sargent's Stereo I know they aren't local, but they are very knowledgable and friendly.
Old Dec 9, 2004 | 07:53 PM
Yeah pendejo is right. When you go to pick out an amp look at the RMS watts, not the peak. Same thing goes for speakers. Usually a ported box will sound louder and a sealed one will sound tighter and cleaner, but it depends on the sub. I had one 12 inch sub with 800 watt RMS (1500 peak) and a 750 watt RMS mono amp (which means one channel) It shattered my rear window, and could make you puke if you lissen to it for 15 min. turned up.
Heres a good site to visit. They have good examples on amps and speaker and they also have a message board with alot of smart people. http://www.polkaudio.com/car/index.php
