Adjusting Suspension on 04 Raptor
Old Dec 8, 2004 | 07:20 PM
redwingsrule05's Avatar
Default Adjusting Suspension on 04 Raptor
Can anyone tell me how you adjust the front and rear shocks on a Yamaha raptor 660R 04'?
I need to make it alot softer.
THX
Old Dec 8, 2004 | 07:36 PM
maddog56's Avatar
There are 3 preload positions. The more extended the spring is the softer it gets. Thats the only adjustment you get.
Old Dec 8, 2004 | 07:53 PM
MX450RIDER's Avatar
thats only on the front the back you have a small screw you have to turn its in your manual
Old Dec 8, 2004 | 08:01 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
there are 3 adjstments in the rear
in back, loosen the lock nut and tighten/loosen the large nut at the top of the spring for pre-load.
turn the screw on the reservoir to adjust how fast the shock compresses.
adjust the screw at the bottom of rear shock for rebound (how fast it springs back up).
Old Dec 8, 2004 | 08:10 PM
maddog56's Avatar
Thanks for picking up my slack guys, I didnt catch that he had asked for the rear too.
Old Dec 8, 2004 | 08:20 PM
So turning the screw out will soften the suspension?
Old Dec 8, 2004 | 08:23 PM
Bing's Avatar
Super Quad Patrol
the screw on the reservoir,,,,if you turn it out,,,,,will allow the spring to compress quickly
the screw on the bottom of the shock,,,,if you turn it out,,,,,it will allow the shock to return quicker
the one on the bottom you want to adjust so that the seat doesnt come flying back up too fast,,,,but not so slow that it begins to stay squatted when you go over a few whoops in a row
Old Dec 8, 2004 | 08:24 PM
Bing's Avatar
Super Quad Patrol
screw both of them in all the way (gently)
then back them out in incraments of 1/4 turn,,,,,feeling the compression and rebound as you go
Old Dec 8, 2004 | 08:26 PM
Bing's Avatar
Super Quad Patrol
if you get the rear dialed in properly,,,it can have a drastic affect on how well the bike handles (and abuses you)
if it isnt dialed in,,,it will be a handful to control,,,and basicly slow you down
Old Dec 8, 2004 | 08:39 PM
Cool thanks a lot for the info
