Raptor jetting with just exhaust
Old Dec 9, 2004 | 07:12 PM
yamahaking69's Avatar
Default Raptor jetting with just exhaust
ok my atv has already been jetted and idno wht it is too... wht are the exact turnings and jetting settings i should have it on with an hmf exuast?
Old Dec 9, 2004 | 07:20 PM
sixsixT's Avatar
It depends on your airbox and elevation too. Even knowing that no one can tell you the EXACT jetting but can get you close.
warriorbansheeboy's Avatar
depends what you want
Old Dec 9, 2004 | 07:35 PM
i just want it to run good in low mid and pinned and no boggyness
Old Dec 9, 2004 | 09:11 PM
rotty150's Avatar
any air box mods? If you dont have any mods to your air box, run 150/155. Air-Fuel screws are 2 1/2 on the left and 3 on the right. I never touch my air fuel. (If you do have an open airbox run 180/185 jets in this cold weather with your needle on the 4th clip. If it pops lean move your needle to 5 and you'll have it. good luck!!
Old Dec 9, 2004 | 10:51 PM
ok i have cut holes in the top of my airbox. so would tht still be 150 155?
Old Dec 9, 2004 | 11:12 PM
rotty150's Avatar
how many? how big? do you run a K&N or high flo filter? If you have big a$$ holes or cuts with a high flo, start @ 160/165, if it falls on it's face and doesn't want to run work your way down 155/160 and so on till you find the combo you like best. If you just about have it but it pops lean lift your needle up from 3 to 4 clip.
If they are little holes with a stock filter go 150/155 with the needle on 3, if it pops lift your needle up to4
It will get you close enough to dial it in?? good luck
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
