02 P 650 charging system dead,help.
Old Dec 12, 2004 | 05:03 PM
MALAHATMAGUIVER's Avatar
Default 02 P 650 charging system dead,help.
Went for a ride today,dead battery,had to get towed by arctic cat(sorry to let you guys down)
no output from charging system,any info would be appreciated.
DON'T HAVE MANUAL!!! thanx M/M.
Old Dec 12, 2004 | 05:19 PM
birdbath's Avatar
check the plug in the rear.It's on the right hand side in the back and it has a round black rubber piece over it.Check to make sure it's plugged in.If it isn't plugged in... you will be able to ride till the battery dies.That plug has to be together.If it came unplugged your charging system won't work.This happened to my buddy's and that's how i fixed it. Good luck
Old Dec 12, 2004 | 05:20 PM
I guess I should of check everything before I posted....one of the plugs at the back of the atv along the frame opposite the exhaust was disconnested but still in the boot.hooray!!!thanks.
M/M.
Old Dec 12, 2004 | 05:21 PM
Thanks birdbath!!!
Old Dec 12, 2004 | 05:27 PM
birdbath's Avatar
Awesome..I knew right away that was the problem.whenever you have any electrical problems with this machine......Go back to the basics.It's usually a simple fix.And ALWAYS check your fuses with a meter because you can't always tell by looking at them.
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
