cluch question
Old Dec 13, 2004 | 10:54 PM
Jordanw's Avatar
Default cluch question
the cluch on my400ex is getting stiff, is it a big job to change the cluch, thanx
Old Dec 14, 2004 | 12:18 AM
Polaris500HO4x4's Avatar
no its really not bad... the plates just slide out of the basket.. be careful to no loose stuff tho
Old Dec 14, 2004 | 01:03 AM
Semms40oz's Avatar
also the main nut that hold the clutch together has a locking feature that uses a grove in the shaft and a flange on the nut is pressed into that grouve... Your gonna need a dremal and if you do it carefully you can reuse the nut as long as you use some loctite when you put it back together.
Old Dec 14, 2004 | 01:05 AM
Semms40oz's Avatar
oh and what do you mean by "getting stiff". don't replace the clutch till it is slipping.
Old Dec 14, 2004 | 10:52 AM
ZillaRider87's Avatar
my clutch lever was a SOB to pull, all i did was replace cable, and it pulls with ease now, maybe thats it?
Old Dec 14, 2004 | 08:43 PM
NotuRaptor2's Avatar
I agree on replacing the clutch cable. A bad clutch will not cause it to require more effort to disengage.
Get a PEP EZ pull lever. I got mine from NACS. It makes a big difference.
/Jon
Old Dec 18, 2004 | 11:54 PM
cezar21's Avatar
actualy a stiff clutch can be cause by a bad clutch if you where to get ur clutch to hot for what ever reason and the plates warp it can get stiff but most of the time it gets realy lose and slips alot. befor i replaced mine i bought a manual which made the project duable but you have absoutly got to tighten ever nut down to their specfications(you will need a toroqu wrenck for sure). the lock nut is a beast to losen if u don't have an etension for your wrench but can be re used like Semms40oz said. the over all job is easy and the plates come out very easily.
ps u might want to check ur presure plate min hada a realy bad crake in on of the main pilars.
EIF
Apr 20, 2017 07:15 PM
bvandass
Oct 8, 2015 09:13 AM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
