bombardier ds 2 stroke 90
Old Dec 15, 2004 | 07:48 PM
natenate's Avatar
Default bombardier ds 2 stroke 90
on my 90 on the left hand side on the engine case there is a dip stick that says oil.
does anybody know what kind and how much?
even the dealer doesn't know.
Old Dec 17, 2004 | 11:04 PM
spike99's Avatar
Don't know the answer to your question. Just wanted to "bump" your question to the 1st page and kindly ask the folks who have a DS-90 2 stroke to "try and help this fellow mini-quader out". thanks.
Perhaps its the dip stick to check its tranny level fluid? I know, I'm guessing to spark a few ideas...
Old Dec 18, 2004 | 12:09 AM
watzupdog's Avatar
bump
Old Dec 18, 2004 | 10:00 AM
natenate's Avatar
thanks for help it is on the tranny side but it is a auto.
Old Dec 22, 2004 | 01:15 AM
Fastestdad's Avatar
That is the gearbox oil I cant remember what oil you can ask any polaris dealer ,same as predator 90
Old Dec 22, 2004 | 06:31 PM
HQR109's Avatar
yes that is the gear oil. there should be a drain plug on the bottom of the engine case almost directly under the dip stick. there also should de a vent tube coming out the other side of the case. the oil should be 80 to 90 weight gear lube. it is best to change this often expecially if you ride in mud or water. drain all the oil. fill until it runs out the vent tube and your done.
Mark
Old Dec 22, 2004 | 06:42 PM
natenate's Avatar
Mark
thanks for the information and I will check this out.
Old Dec 22, 2004 | 07:03 PM
sparky1698's Avatar
If its the same as a Polaris i would use Polaris brand AGL full synthetic. It is in a blue bottle and blue in color. We put it in my boys 90 and it does seem to make a diff.
Old Dec 22, 2004 | 10:55 PM
spike99's Avatar
Many people have told me they like the blue Polaris oil much better then standard 80/90 gear oil. I'm positive both would work but Blue thick liquid is much easier to see on a dip stick &/or through a sight window. And much easier to tell if you have white water streaks in the oil. Also, most CVT minis only take 7 oz of tranny oil. That's a little more then a 1/2 coke can. And believe you me, 7 oz can be filled very fast. If you overfill, drain it to normal operating levels. I heard too much oil may blow tranny seals. The oil needs room to move around.
Hope this helps as well...
Old Dec 23, 2004 | 12:04 AM
sparky1698's Avatar
Your right Spike it doesnt take much, found out first hand. The blue is a synthetic so its alot thinner than reg gear lube. More like ATF.[img]i/expressions/face-icon-small-cool.gif[/img]:
