Got it running but need some help
Ok I just installed a 400ex carb with a stage 2 jetting on my 250x. It has a RCM exaustand smaller front and rear sprockets. Ok it runnes great at idle and when you just cruise at low throttle but when you get on the gas it really starts to bog down. I am thinking that since the carb is probably set up for a 400 then I am probably running rich. (Am I right?) Well if so I was told I could adjust the needle in the carb to lean it out if true how much should I move the needle. Or if there is something else I am over looking please help.
Almost forgot, put in a new plug, run the bike at wide open throttle and kill it(at WOT) then pull th eplug, it's supposed to be a light tan, brownish color. If it's black, youre rich. If it's white, you're lean. For the main, you can't just adjust, you need to actually buy the jets. I would buy a DynoJet Kit Good luck.
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
