a guestion for you guys!
Old Sep 10, 2000 | 09:13 PM
atvrider300ex's Avatar
my husband put on his new JD Performance +2 A-arms, is there a best position to set them? leaning them inward or outward? you guys are very helpful!! thanks!
Old Sep 10, 2000 | 09:23 PM
Skunky's Avatar
never lean the tires outwards....
7 degrees for desert
3.5 degrees for MX
caster/camber/toe-in/toe-out
Old Sep 10, 2000 | 09:53 PM
thanks Skunky! but what are you measuring with? Doris
Old Sep 10, 2000 | 11:16 PM
mntrailrider's Avatar
Well Doris, you can measure the spacing between the tires with a tape measure and compare the top of the tire to the bottom of the tire. I don't how you would check degrees.
Old Sep 10, 2000 | 11:23 PM
Skunky's Avatar
you can do the tape measure/straight edge/string method... but I adjust mine often and I have access to a caster/camber gauge You can get one from longacre at www.longacreracing.com $149.95.. If you get one get the one with the magnetic adapters.. You bolt the adapters to the wheel hubs.
Old Sep 10, 2000 | 11:53 PM
THANKS AGAIN!
bafisher1986
Jul 21, 2015 04:12 PM
rcappie4
Jul 18, 2015 07:51 AM
Robinhood
Jul 13, 2015 09:13 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
