'04 polaris sportsman
Old Dec 21, 2004 | 09:12 PM
wehester's Avatar
Default '04 polaris sportsman
Okay, I've read through most of the forums concerning this subject but i haven't found what I need.
1. The front right hub on my sportsman will not engage.
2. the first trouble i had, i took the hub apart and found that the armature plate had come loose and had been damaged.
I replaced the plate and the front hub still did not engage.
3. then i swapped the roller cage assembly and armature plates on both sides and the left would pull and the right
would still not pull
4. i took the right hub apart again and checked the electromagnet and it would hold the armature plate to it
5. the inside of the hub where the rollers contact looked a little glazed so I cleaned the surface good but i haven't
reassembled it yet
I've tried everything I can think of and if the surface cleaning doesn't work what should I try next?
I could really use some help.
Old Dec 21, 2004 | 10:38 PM
chevy72402's Avatar
did you check your wires to the wheel? We had some wires that broke and wouldn't engage. I fixed the wires and it now works.
Old Dec 22, 2004 | 03:30 PM
lanalder600's Avatar
Here is somthing you probably already thought, is it still under factory warranty?
Old Dec 22, 2004 | 03:53 PM
BareTread's Avatar
garbage.....
Old Dec 22, 2004 | 04:08 PM
elkbow's Avatar
Originally posted by: BareTread
garbage.....
Get out....don't need someone like you throwing out stupid comments when someone is looking for assistance with their machine...
Old Dec 22, 2004 | 04:17 PM
mtpockets's Avatar
be nice BareTread it's almost Christmas.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 22, 2004 | 04:19 PM
mtpockets's Avatar
double post, my bad! LOL
Old Dec 22, 2004 | 05:41 PM
elkbow's Avatar
ha....just giving alittle friendly 'get the .....out'
merry xmas
Old Dec 22, 2004 | 07:30 PM
Polaris500HO4x4's Avatar
bare u need to get a life... i can tell you havent ridden with a polaris before
Old Dec 22, 2004 | 10:23 PM
BareTread's Avatar
im just doin a little freindly trash talkin, nothin serious. yes i ahve ridden a polaris so i know what they are like. my uncle has a SP700 and its junk, it always breaks down. my honda keeps on tickin.
