who has the biggest lift kit
Old Dec 25, 2004 | 10:59 PM
weewane's Avatar
Default who has the biggest lift kit
trying to find out who has the biggest lift kit for a atv on the market thanks for any help
Old Dec 25, 2004 | 11:04 PM
7QuadSport7's Avatar
2 " to 4" is the bigget your gonna get i think by a company
Old Dec 28, 2004 | 10:59 AM
Cirviver's Avatar
Highlifter makes a great lift kit. Like 7QuadSport7 said, you will only be able to go about 2" because if they made them taller than that it would destroy your CV joints in a short period of time. The higher the lift, the more angle you put on the CV joints and it puts them in a bind. Highlifter engineered their lift kits to give you the most lift without straining the CV joints. I made a kit for my 98 TRX 300 4X4 and the first time I made it too tall. When I rode it down the street I heard a knocking noise from the front and rear end. My joints were at too severe an angle. I re-worked them and made them the same size as the Highlifter and the sounds went away. You do not want to replace the CV shafts and joint because it is not cheap.
Hope this helps!
Old Dec 28, 2004 | 11:07 AM
mudblaster's Avatar
when i got my lift kit the dealer said the biggest he could ge me was 1 1/2"
he also said that if you found any bigger it would be harder on cv joints and axels
so i got the 1 1/2" and it works great.
Old Dec 28, 2004 | 01:08 PM
Vinson581's Avatar
i dont want to even hear about lift kits, unless you run custom axles, you will break cv joints i dont care what anyone says, i have broken 2 whole axles, and one outer assembly.
lift kits will put a extream strain on your drive shafts, all all the sudden it will start out as a metallic sound, next thing the race inside the axle pops apart and gets destroyed.
bottom line in my mind is dont lift unless you know the risks of what i have told you. its not like its just on my vinny, i have seen this on polaris, honda, yammi, and kawi, as well as other suzuki's i feel as if unless you are mudding extream at low crawling speed in 4x4 low range all the time then lifting is a waste.
v581
Old Dec 28, 2004 | 01:46 PM
2phast4u2catch's Avatar
my friend said hes getting new gorilla axles and a 5" lift
Old Dec 28, 2004 | 01:56 PM
Cirviver's Avatar
What kind of quad is he putting the axle and 5" lift on? I would love to see it when it is done.
Old Dec 28, 2004 | 02:01 PM
i think its his older suzuki model it might b his dads his dad has a honda sumthing there both older models hsi dad has the jsut fer yard work he has a ds 650 and my friend has a rm 85 fer play time
Old Dec 28, 2004 | 02:04 PM
i keep up w/ his dad on my 450r everytime i bring it ova he hasta ride it atleast once we all drag race often i usally win and he will win the rest sum times the rm sneeks by but only by a ft or 2 he still learning how to ride a dirt bike
Old Dec 28, 2004 | 06:11 PM
mudblaster's Avatar
i have over 2500 kilometers on my honda with the lift kit on and no probs here.
still going strong.
