Run out of parts
Old Dec 26, 2004 | 07:40 PM
RaptorEater08x's Avatar
Default Run out of parts
I lost the clip for my coil and while i was ridin the coil snapped... I always look for oem parts at cdalesparts.com, nothin there, also none on ebay.. Anybody have any suggestions, where to find a coil and a clip??
Thanks i really need the help
Old Dec 26, 2004 | 09:22 PM
TraumaRN's Avatar
You can call ATK, they have a ton of parts, number is on their website www.atkusa.com
Haydug Cycles probably has some as well, check Cdaleparts probably has them as well, probably just need to make a phone call or ask him on www.cannondaler.com
Old Dec 27, 2004 | 12:24 AM
FOX400's Avatar
I noticed you have a k&n Air where did you get it?
01 fx 400
Old Dec 27, 2004 | 01:51 AM
TraumaRN's Avatar
I've seen the K&N on Ebay, but for retail price...
Old Dec 27, 2004 | 05:17 AM
WISTECH's Avatar
K&N on a dale? Get that off there and put a foam one on it. I might have a extra clip for the coil. Ill check when i get to the shop.
Old Sep 18, 2005 | 09:01 PM
TheNadine's Avatar
I have a K&N and a crap uni-air but i wont ever switch back to foam filters since i started using K&N
Old Sep 18, 2005 | 09:07 PM
Sandgod's Avatar
Rocky Mountain ATV sells K&N's for our quads..
Old Sep 20, 2005 | 11:25 PM
CHAIN6AW's Avatar
I wouldnt use a K&N to filter my farts through..... they are junk. If you do run one...at least buy an outerwear.. those little things are worth their weight in gold!
Old Sep 20, 2005 | 11:56 PM
claas900's Avatar
..Your wasteing your time with cdaleparts. Call Haydug or Brad with blackwidowatv.
Old Sep 22, 2005 | 11:38 AM
WISTECH's Avatar
The K@N for the Dale doesnt have a very good seal against the base and when in rough terain it will not seal from movement. The stock rough foam filter is the best filtering. For parts see Haydug ,Caniboomer or Black widow or ATK.
