400ex big bore kit how much improvment?
Old Dec 27, 2004 | 02:09 AM
gonetothedunes's Avatar
Default 400ex big bore kit how much improvment?
i always ride my father inlaws 400ex but it is very slow, and i was wondering how much extra power/speed i can get with a 440 big bore kit
Old Dec 27, 2004 | 10:30 AM
OregonDunePatrol's Avatar
40 HP is the norm for a 440. I estimate that I am about 43-45 horsepower with my EX. My goal is to be around 52 by the summer.
Old Dec 28, 2004 | 12:04 AM
will it be a night and day differance or just very mild differance also what is the stock hp on a 400ex
Old Dec 28, 2004 | 12:19 AM
nosliw's Avatar
like 28 or so
so 45 and 28? one HELLUVA difference [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 28, 2004 | 12:32 AM
and buying that kit i should need no other parts just the sleeve piston cam, and i have to resleeve the jug is this all i have to do to get the 45 hp or around there
Old Dec 28, 2004 | 09:58 AM
tprender's Avatar
I went with a cam at the same time being that you have it apart. Also, put the oversized studs in at the same time. If you don't you will blow head gaskets. You will like the end results. I went with a larger front sproket because of the extra power, 16T. and if you realy want to wake it up get a different carb.
Old Dec 28, 2004 | 10:19 AM
Gone,
This is what you need to make a successfull 440 with around 45 HP...
1 ) 440 Big Bore Kit (Piston, Rings Sleeve)
2 ) Edelbrock 38MM "Doug Eichner" Carburetor
3 ) Web camshaft
4 ) Web Valve Springs
5 ) Web Hardweld Rocker Arms
6 ) Web Shortened Valve Guides
7 ) LTE Dual Exhaust
8 ) Web 1mm oversize intake and exhaust valves
9 ) Heat Porting
10 ) Labor to Install
This is what I have on my EX. You can get similar parts from different manufacturers. Those parts and labor should be about $3000 depending on the shop and where you buy your parts.
Old Dec 28, 2004 | 10:43 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Just boring it to a 440 won't make much of a difference, it is the combination of multiple parts that make the horsepower like oredondune listed.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
