TM45 Glamis Jetting
Old Dec 27, 2004 | 05:38 AM
ERBEDS650's Avatar
Default TM45 Glamis Jetting
OK guys! Jetting for a TM45 for Glamis?
Open air lid, and a end cap.
50 accel nozzel, what size needle? main? Pilot?
And ohh, what are you guys doing about the vent on the intake boot??
OK called woods they said go with a 145 main, and 25 to a 30 pilot, 96 needle, clip 3rd notch.
OK what the hey went to RWR
Ellot was great!!! changed the whole carb right there for me, took the accel pump off and rejettted it!!
Old Dec 27, 2004 | 11:07 AM
Eaglecollector's Avatar
It's been to long since I ran the TM45 to remember all the settings I had on it. I also ran the direct mount filter but the main was a 150 and I know I had to have the squiter / nozzle pointed right at the needle. I think i had the clip in the middle or maybe one richer. Not sure about that one.
The breather hose I bought a longer one and routed it so that it went into my air box and put a cheap filter on it from the auto parts store.
I had the 45 set up so well that there wasn't a big wow diff when i went to the duals.
Old Dec 27, 2004 | 12:17 PM
eRo's Avatar
eRo
if u are not using the carb mount filter, i would try a little richer on the main and needle. maybe 155-160 main and needle on 4th position. there is more velocity with the snorkle tube. some run the crackcase vent hose to that vent on the snorkle. i just pulled off the elbow on the vent and filled the hole with caulking.
Old Dec 27, 2004 | 10:41 PM
Squatcher's Avatar
Before most of my motor work I ran a 145 Main, 2 clip from the bottom, 40 polit, #50 nossile pointed right at the center of the needle. Make sure you run a 97 needle. I even run the 97 with my motor now. 96 is way to rich. Set the Accel. pump to start real early less than 1/4 throttle. If you get blips when given full thottle adjust you accel pump till it is smooth when OWT. That should work out well. Have fun we are going to buttercup.
Old Dec 28, 2004 | 12:09 AM
ERBEDS650's Avatar
Yeah Im not to used to the accel pump removed, Elliot stated that in normal off road riding that I wont be flicking the throttle and hit that hesitation, but he said LOL if I wine enough I can have the accel pump re-hooked up.
Old Dec 28, 2004 | 01:10 AM
blue250r's Avatar
What size of main would you use at sea level for the Tm45. As i always see posts about jetting them ,that seem to be jetted leaner than stock carbs ??
Old Dec 28, 2004 | 11:45 AM
eRo's Avatar
eRo
the tm main jets are physically larger than the main jets in the bsr 42. as for comparing like main jets between both carbs, i don't know if they would flow the same or not..
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
