atc 200x carb jetting ?
Old Dec 27, 2004 | 04:07 PM
skinny's Avatar
Default atc 200x carb jetting ?
I have a 1983 200x which i put a 1983 185s motor in. It has been bored .80 over with a wiesco high compression piston it has all new valves, rockers, and a brand new high performance racing cam which is a web cam. It has cobra alluminum race series exhaust and has been ported and polished. I put the stock 200x carb on becuase the 185s carb would not work becuase it wanted more fuel. Then after i put the 200x carb on it still needs more fuel so i took out the stock 110 jet and replaced it with 115 jet and in 1,2,3,4 it runs good but in 5th gear it bogs down like it is choking out what shall i do ?
Old Dec 30, 2004 | 04:19 PM
Rexkarz's Avatar
How do you pull start that thing with all the compression?
Old Jan 1, 2005 | 02:15 PM
skinny's Avatar
you just be a man and hope the de cmpression is in a good mood when you go to pull the thing over
Old Jan 3, 2005 | 12:24 PM
GlennJ's Avatar
What year carb was the 200X carb off of? The 83 model year machines used a 110 main, the 84 and 85 used a 108 main.
Old Jan 3, 2005 | 02:53 PM
dragracer789's Avatar
If its bogging in 5th then your probly to rich. I couldnt imagine a 185 with a stock cam and ports to be over 110, but try a 112 and see if its better.
Old Jan 3, 2005 | 10:35 PM
skinny's Avatar
ITS NOT A STOCK CAM ITS A WEB CAM AND IT IS 5X BIGGER THAN A STOCK CAM
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
