Suzuki LT80 stock wheel size
Hi
Well, I now have one bent 2000 Suzuki LT80 rim. The stock size is 8 x 5.5 ? It seems to measure out bigger than that. Just want to double check before ordering the wrong size. I really only need one stock rim, but only have seen 2 (rust) with old tires on Ebay. Anyone know of a source for one stock rim? I guess I will order new set of two from Rocky Mountain in the 8 x 5 size Aluminum. I would like to get the James Lucky set of 4 with wider tires but don't really need to spend $240 + Ship.
BTW: I'm glad I read on here about the CARB. fix for the LT80, mine had been setting for a year and would not idle at all. Now it runs like a champ.
Thanks
Thanks
Check Ebay there are always various stock LT80 items for sale there.......
I got the Lucky set up. A little expensive but I felt worth it since we need the grab for rough terrain...Makes the quad more stable in the rear too. A set of front extenders and those rear wheel and you have a different machine. I should add that we had our motor done by Jack LT80 so it helps to turn those big tires...
Jul 21, 2015 03:03 PM
Jul 15, 2015 02:07 AM
