Starter question for Scrambler 400
Old Dec 31, 2004 | 01:11 PM
gearheadjdr's Avatar
Default Starter question for Scrambler 400
I was wondering how hard it is to change the starter on a 1999 Scrambler 400 4wd, Mine quit and either needs taken off and cleaned or replaced. I'm not really sure where the starter is even located at on this quad. So I kind of need to know how to get to it and do I need any special tools to do the job.
Old Dec 31, 2004 | 01:23 PM
thewayout420's Avatar
its pretty easy to take off..youll need to pull the recoil housing off the engine,take the 2 bolts out and then you need to take your clutch cover,the clutches and also the inner cover off,there is a bracket bolted to the starter and the frame,take the 2 bolts that are bolted to the frame out and then the starter will come out after you remove the wires of cource..you will need a clutch puller to get your primary clutch off..hope this helps..
Old Dec 31, 2004 | 01:50 PM
That shjould be a big help,
Thanks!!
Old Dec 31, 2004 | 02:13 PM
your welcome..[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 31, 2004 | 06:14 PM
vig's Avatar
vig
You can get from the bottom also tip up the machine and remove the skid plate. Little tricky but it can be done. lot less parts to remove.
Old Jan 1, 2005 | 09:02 PM
Somebody told me you could get to it that way, but I didn't think that was possible.
Old Jan 1, 2005 | 09:23 PM
Crawdad's Avatar
Yeah, as Vig suggested you can go from the bottom alot easier. I just flipped mine up and let it stand on the rear grab bar and then it's really easy once you remove the skid plate. It's actually pretty stable once you stand it up like that.
Chances are your brushes just need replacing. Pull the starter and check those. It's alot cheaper than replacing the whole starter.
Cole Hadden
Jun 15, 2025 09:05 AM
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
maxjung
Jul 13, 2015 05:11 PM
