Too tight a chain..what will it do?
Old Sep 12, 2000 | 11:11 PM
rottwolf's Avatar
Hi all. I have a 96 banshee with a 13 tooth front sprocket and I just bought a new RK X-ring chain on it. Well, the stock is 104 links. I tried installing it at 104 links, and adjusted the adjuster as tightI could, and it was still way too loose. So I took a link out, now at 103, and loosened the adjuster as much as I could. Now it's way too tight. It has a slight bit of play in it, but not much at all. Will it stretch quickly? I would think this would be not too good? Is it that dangerous? You help is appreciated!
Thanks,
Jason
Old Sep 12, 2000 | 11:48 PM
THEXOTIC1's Avatar
Too tight a chain can snap by the flexing of the swing arm and your weight.
Old Sep 12, 2000 | 11:50 PM
DunePilot858's Avatar
Well lets see... you could have serious wear problems on the counter shaft itself and may cause it to bend. The added stress on the bearing inside the case might do some damage... you do know that you should adjust the chain when your sitting on it with the suspension bottomed out. 1" of up and down play is about right.
Old Sep 13, 2000 | 12:28 AM
rottwolf's Avatar
So, will the new chain stretch fairly quickly?
Jason
Old Sep 13, 2000 | 12:39 AM
THEXOTIC1's Avatar
Rk has a strong lbs limit it should strech out in one day of riding but probably not alot. I tightening my chain about 3-5 rides
Old Sep 13, 2000 | 01:15 AM
rottwolf's Avatar
I guess what I'm trying to ask is it safe to ride it and let it stretch? Or what?
Thanks,
Jason
Old Sep 13, 2000 | 01:50 AM
99blueblaster's Avatar
how much play do you have in it now. If it has no play what so ever than it is too tight. If it is between 3/4 to an inch of play then it will stretch fine the first ride.
Old Sep 13, 2000 | 02:39 AM
hot_shoe_cv's Avatar
It won't stretch as quickly as the possible damage to sprockets & the previously- mentioned countershaft & bearings .Why can't you add a 1/2 link to the chain?
Old Sep 13, 2000 | 02:43 AM
rottwolf's Avatar
It has like, 1/4 of an inch moving upward. Next to none if you try to move it down.
Thanks,
Jason
Old Sep 13, 2000 | 10:03 AM
Dom's Avatar
Dom
Try to grind the splice to move your housing more to the front, I had the same probleme and done that on my 99 Banshee.
