baja lights with scoops?
Old Jan 6, 2005 | 07:45 PM
learnenem's Avatar
Default baja lights with scoops?
Is it possible to utilize the baja lights while also using front end air scoops?
Old Jan 6, 2005 | 08:13 PM
Sandaholic's Avatar
I did for about 2 years. I had the shrouds mounted directly to the guards of the Baja lights. Genuine Baja lights from BRP are not cheap, I think they are around $130. The light output can be compared to fog lights used for auto that can be found fairly cheap at auto parts stores. They use a standard H3 bulb.
A sweet alternative would be a set of trail techs mr11 hid in a frame mount style. They will draw a small amount of watts, but put out a nice white light. It wouldn't be hard to wire them to turn on like the factory lights or you could wire a separate switch.
Old Jan 7, 2005 | 03:18 AM
BlackHawk's Avatar
I think wiring a seperate switch is the ticket, I'd love to turn on the 'Baja" lights when the low beams are on - ideal for navigating camps!
Old Jan 7, 2005 | 11:09 AM
Mrneg9's Avatar
There really is no need to. I put the shrouds on my bike and there was no way the light guards would fit. The shrouds serve the same purpose as the light guards. Later, D
akguy31
Aug 31, 2019 04:34 AM
Club News and Events
May 28, 2016 08:02 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
