350x tranny issue
Old Jan 11, 2005 | 08:14 PM
MY86ATC350X's Avatar
Default 350x tranny issue
ok now recently my 350x is a little rough on the neutral its kinda hard to put it into neutral when its running, and when its off its goes into neutral easliy. what can i do to fix that, mabe a full rebuild?
Old Jan 11, 2005 | 09:47 PM
teamgreen77's Avatar
new clutch would probably do the trick.
Old Jan 11, 2005 | 11:06 PM
Cdogg's Avatar
That is nothing out of the ordinary for a 350X. Every 350X I have ever ridden is hard to put in neutral when the engine is hot and running. Also, the clutch baskets get grooves from the fiber plates. I put a clutch in my 350 a couple months ago. I had to file the grooves down a little. But if you have it down that far you might as well put fibers in it.
Old Jan 12, 2005 | 10:30 PM
dragracer789's Avatar
Try adjusting the clutch so it disengages more, but make sure there is still a LITTLE bit of slack in the cable. It might just be that the clutch isnt fully disengaging, A very common problem, or it could be something internal like the push rod is worn to badly.
Old Jan 14, 2005 | 06:40 PM
my clutch also feels alittle slippy at some times, mabe putting a new clutch would work and also changing the clutch basket, where can i get a new clutch basket and clutch, i prefer putting performance series ones. so what u guys think i should do.
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
cody500ho
14
Aug 14, 2015 05:03 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
