1988 tecate 4
Old Jan 13, 2005 | 10:31 AM
QuAdRiDeR200369's Avatar
Default 1988 tecate 4
i found a 1988 tecate 4 in the paper for 1500$ and needs tlc. i was just wondering are these things reliable when fixed up? are parts hard to find? also anyone know what the top speed? how are they in snow? is it possible to clean it up and sell it for more? thanks guys
Old Jan 13, 2005 | 11:22 AM
kwackermann's Avatar
THat's quite a price, sounds like it probably needs aloth of help.reliability is just about equal to any comparable 2- stroke. Parts are about as hard to find as hens' teeth, they are very very scarce. It's probably not the greatest in snow as it's a 2wd and high strung at that. Fact is- the engine was actually hotter than the 250R but the chassis wasn't quite as world class.
Old Jan 13, 2005 | 11:44 AM
i might go take a look at it and try to get the price down alittle more. cant hurt to try. you know of any problems i should look for? thanks
Old Jan 13, 2005 | 04:48 PM
ranger696f's Avatar
the parts arnt that hard to find but if the moter sound good and dont smoke the rest you can fix but if its like you said ylc then get the price down and get it i know of places to get parts
Old Jan 13, 2005 | 05:01 PM
mentalmojave's Avatar
smoke wouldnt be a bad thing......its 2-stroke
Old Jan 13, 2005 | 05:45 PM
KVRMUDDRUNNER's Avatar
LUCKY!! Usually you cant touch one for 2 or 3 grand.
Old Jan 13, 2005 | 07:54 PM
any one know what the top speed is?
Old Jan 14, 2005 | 01:45 AM
pendejo's Avatar
Mid 70's for a stock good running one. I don't know of any problems specific to the T4, but as with any used quad, check the frame/bearings and seals/suspension for cracks, wear, abuse. I always check the radiator for oil, try to pull the plug and stick your finger over the spark plug hole and see if it has good compression. Look at the plastics, tires, chassis components for wear. Basically, just go over the whole quad and make an offer accordingly. Good luck.
Valder
Nov 28, 2020 07:38 AM
big_g_squared
Jun 28, 2015 04:17 PM
CALDS650
Mar 13, 2001 10:20 PM
tecatekx
Apr 27, 2000 06:33 PM
SandDraggin
13
Apr 20, 2000 02:07 PM
