how will this do racing
Old Jan 15, 2005 | 03:06 PM
blaster5415's Avatar
Default how will this do racing
how will all of this stuff on a blaster do in racing
from CTracing, a race porting and polishing, Head milled and rechambered,
A New Wiseco Piston
4degrees timing advance
Racing Clutch Setup;
Vforce2 reed system with boyesen pro series reeds,
Pro-tec intake manifold
Boost bottle
UNI Dual layer pod Filter clamp on
K&N Clamp On as well
Mikuni 35mm TMX Flatslide carburetor carb also has the Boyesen Flot bowl For more response
You will get a almost brand new FMF fatty gold series and the Power core2 Silencer,
The Coil which has been customize with a 9mm MSD race Wire and cap.
aftermarket suspension probably works
holeshots
thanks
Old Jan 15, 2005 | 03:13 PM
poopy's Avatar
depends on what kind of racing. that sounds like a pretty nice blaster.
Old Jan 15, 2005 | 03:22 PM
probably harescrambles and mx
Old Jan 15, 2005 | 04:18 PM
maddog56's Avatar
Pretty good for a blaster. Looks like some of the items arent installed/purchased yet? Or are you purchasing this?
Old Jan 15, 2005 | 06:08 PM
Banshee392's Avatar
-Dont get Vforce 2 reeds...Get G3's
-Why a boostbottle? They do nothing for the blaster unless you have a PJ series carb..
-And why FMF? They are better pipes out there such as LRD,Dynoport,Graydon.. (Dont respond such as "OMGZ You have an FMF pipe!?!?!" Answer: I got it $200 new so I couldnt pass that up)
Other than that..You have a nice blaster!!
Old Jan 15, 2005 | 10:20 PM
yea im purchasing this so yous think it will do alright in a harescramble or mx
Old Jan 16, 2005 | 12:46 PM
clover's Avatar
It should do pretty dang good in both.
Old Jan 20, 2005 | 07:04 PM
RoscoePW's Avatar
its be a real good mx racer, so long as it follows the guidlines.
Old Apr 6, 2005 | 09:51 PM
jas's Avatar
jas
i think it will do pretty good
Old Apr 21, 2005 | 08:34 PM
1988fast250x's Avatar
personally i think you wasted your money on that boost bottle its just going to wear you motor out quick
If i were you i would have stuck a large big bore kit on it
