Raptor 660 Sprocket Removal
Do I need to remove the chain to change out the sprocket ? Will loosening the chain be enough ? The chain has five hours max on it so it should not be stretched.
Thanks !
Thanks !
I assume you are talking about the front sprocket
remove sprocket gaurd
bend lockwasher tangs down
remove countershaft nut
change sprocket
adjust chain to proper tension
no need to remove chain
change sprocket
