banshee balance pipe
what is the purpose of the balance pipe that connects the two carbs and can i replace it with any oold pipe or hose or does it have to be a certain diameter i lost mine and dont have the money for a boost bottle
Just a hose or pipe will work fine, what that tube does is balance the vacuum/pressure differences in the carbs and cylinders to make fuel delivery more smooth,so the pulses from one don't mess up the intake of the other. if you had a small can with a fitting on it you could make your own boost bottle with a "y" fitting !! But just to keep it running, a basic tube across the carbs will work fine.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
