K & N Question
Old Jan 18, 2005 | 07:46 PM
12pointbuck's Avatar
Default K & N Question
I am a new member here so I hope I am doing this right....Anyway, I have had a rancher for about four months (great machine by the way) and I was thinking about installing a K & N air filter. I have a few questions before doing it: 1) can I do it without jetting the carb 2) can I leave the carb cover off or should I leave it on 3) will it make a noticable difference 4) is it worth it? I have read a variety of resposes to similar questions but they never really give an answer one way or the other. I know everyones experience may be different but I am hoping that I can get some good feedback for riders who have had to make the same decision.
Old Jan 18, 2005 | 08:18 PM
Vunit's Avatar
Well yes it's worth it, your quad will breath better and ahve better throttle response, yes you can put a filter on without jetting the carb, i'm not to sure by what you mean by leaving the carb cover off maybe your talking about the airbox lid off which a lot of people to for more power that's fine to do as well, and it worth it cuz you'll have better throttle response. You wont really see a major increase in power with just a filter but yeah if you get a pipe and jet it and all that other stuff yeah big difference but this is a great mod for a rancher.
Old Jan 18, 2005 | 09:47 PM
86LT250RFatty's Avatar
You will get better throttle response. If you keep the airbox lid on, you will not have to re-jet, if you take it off, you will have to, but you will gain some extra HP too.
Old Jan 18, 2005 | 11:55 PM
TRIPLELSTROKER's Avatar
I installed the K&N filter and jet kit, plus the hmf pipe for a friend of mine on his 01 rancher 4x4 a few weeks ago..talk about waking it up! He now pulls the front tires off the ground in second anytime he wants to. I have the same set-up on my Foreman, it made a difference, but nothing like on the Rancher..I am sure the filter helps a lot, but i believe the combination of the slip on muffler helps alot. The stock muffler is so baffled it really hold the Honda back. I have read several post on here and in articles from magazines about Hondas exhaust being so restrictive. I sure believe it to be true from the experience on these two machines mentioned above. Try it, I believe you will like it. The filter alone may make a good difference. You can always add the jet kit and slip on later.
Old Jan 19, 2005 | 09:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I ran K&N's on all my bikes for years, but have now gone back to UNI foam. I just like the added security of an inch of foam, vs a wimpy little piece of cotton that you can see right through! Save the K&N's for street machines.
The most restrictive thing on your stock Rancher intake is that screen insert (it is a spark arrestor in case there is a backfire into the carb). Also, being a ute, you might want to leave the lid on for riding water and mud. Anyway, if you insist on a K&N (always use an outerwears as well), it will have minimun effect if you are running the stock muffler and stock airbox.
Old Jan 19, 2005 | 11:38 PM
lazer3's Avatar
Here is something to try also. I changed over from the heavy oil that Honda uses to K&N's filter oil with the stock foam. It made a world of difference on the top end power.
I used K&N filters for years on dirt late models and they never gave me any problems as long as they were cleaned regularly.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
