Carrier Bearing Free Play
Old Jan 25, 2005 | 03:19 PM
Woodman262's Avatar
Default Carrier Bearing Free Play
Should there be any noticeable movement of the rear axle in a side to side or up and down movement within the carrier bearings?
Old Jan 31, 2005 | 12:14 AM
TractorPacker's Avatar
Do you have a balloon?
On the sport quads there shouldn't be any "noticable" play. There will be a couple thousandths but not real movement. On a 400ex for example you will get 2 maybe 3 years out of those bearings. If you think they are bad they prolly are.
Old Feb 5, 2005 | 08:56 PM
stuck's Avatar
I had a Polaris Trail Boss that had play. When I toke it apart the old bearings had no more play than the new ones. If you can turn the nut in it will tighten it up so you don't have any play. The nut on my axle was so tight I ended up ruining the nut so I had to replace that as well.
wendal
Aug 3, 2024 10:03 PM
bmxatv10
Oct 14, 2022 06:23 PM
2quiker
Mar 22, 2022 08:36 PM
Elkaholic
Sep 6, 2015 02:44 PM
