how many people run race gas in there DS
Old Jan 26, 2005 | 01:03 AM
thumper650's Avatar
Default how many people run race gas in there DS
How many people run race gas in there DS and why is it so much better. i want to mod my ds but i ride to much to ride with race gas. $50 for 10 gals!!!!!!!!
Old Jan 26, 2005 | 01:57 AM
Sandaholic's Avatar
The only reason to run race gas in the DS is for high compression piston or turbo. If you are running a lower compression piston, you don't need to run race gas.
compression ratio will dictate what octane you need to run.
Old Jan 26, 2005 | 02:14 AM
thumper650's Avatar
well i want to modify ny ds but i dont want to run race gas so what can i do to it besides BIG GUN and VORTEX CDI
Old Jan 26, 2005 | 02:20 AM
Sandaholic's Avatar
You can do almost any type of mods you want as long as you keep the compression ratio down or the turbo boost low
Old Jan 26, 2005 | 02:22 AM
thumper650's Avatar
then what mods shuld i do i want low end and mid and high end
Old Jan 26, 2005 | 02:37 AM
Sandaholic's Avatar
In another post you said you wanted to build a 730 big bore. There is no reason why you could not run a 730 big bore with a low compression piston. Race head, cams, etc do not determine what type of fuel you need.
You want more power in low, mid and high rpm ranges. So you want more power everywhere! The biggest factor as to where the power is focused is from the cam grind. A good engine builder will suggest a proper cam for your ridding style
Your limit to what you want to do is money, not what type of fuel. You can design an engine to run on what ever grade fuel you want.
On a side note, some people think its crazy if you spend $4k on your engine but don't want to spend the extra $2 a gallon for race fuel.
Robinhood
Dec 26, 2015 10:28 AM
kbazzy
Sep 26, 2015 11:26 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
