2000 KAWASAKI /PRAIRE 300 4x4 QUESTION
Old Jan 26, 2005 | 08:51 AM
gsx678's Avatar
Default 2000 KAWASAKI /PRAIRE 300 4x4 QUESTION
Hey all,
I just got my hands on a 2000 PRAIRE 300 4x4...
This thing is very cool..Tons of power and good handling.
My question is do the rims from any other Kawasaki or anything else for that matter fit on the PRAIRE 300??
Mine needs tires and I ran in to someone that has a set of 750 BRUTE FORCE tires and rims for sale.. WILL THESE WORK??
Also if you know of any other items that might be swappable with the PRAIRE 300 4x4.
Thanks alot,
Old Jan 26, 2005 | 11:35 AM
killzoneq2's Avatar
NO they will not... Dont buy them, U need wheels that come off of a RIS ATV with your bolt pattern. They are considered all front wheels. what u need is 4 front wheels due to your IRS.
Old Jan 26, 2005 | 11:49 AM
newbeatle's Avatar
After reading KILL's post, either he or I am corn fused...
the 300 Prairie has 4 on 137 mm bolt pattern... all utility quads that Kawi makes, that I'm aware of have 4 on 137mm bolt pattern EXCEPT the 750 Brute force ( because of it's IRS suspension )... you'll find that the rear wheel is 10" diameter, on your quad, if it's still stock, & made of steel, & wide, the fronts are 12" diameter, & also made of steel... we took the very light weight 12" aluminum wheels off of our ( was ) 650 Prairie, & mounted them on the 300... now it literally has the power of the 360's... you can mount any of the larger 12" wheels off of any of the bigger Prairies ( EXCEPT the 750 Brute), with no problems... while the smaller wheels off of a 220 Bayou will still be the same bolt pattern, they will not clear the brakes, so stick with the 12" aluminum wheels, & you'll be happy...
slowgsxr97
Mar 18, 2022 03:40 AM
Jul 29, 2015 01:24 AM
coolguy420
Jul 28, 2015 01:54 AM
ManuelCarrillo3
Where to Ride
Jul 27, 2015 07:53 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
