What the best carb
Old Jan 27, 2005 | 11:16 AM
thumper650's Avatar
Default What the best carb
what is the best carb fir a 2000 ds650 and money is not a prob
Old Jan 27, 2005 | 11:46 AM
JMAC650's Avatar
If money is no problem I would think about fuel injection.
Old Jan 27, 2005 | 11:47 AM
thumper650's Avatar
where do i get one of those and how much HP does it and does it keep your low end
Old Jan 27, 2005 | 12:25 PM
tweekeronabanshee1089's Avatar
Old Jan 27, 2005 | 01:18 PM
BlackHawk's Avatar
Fuel injection means your engine ALWAYS has 100% correct fuel (assuming the EFI is setup correctly.) So you will have maximum power for whatever your engine can produce in its current configuration.
you can get them here at the link below and I'm sure other places soon.
http://www.kmsperformance.com/
Old Jan 27, 2005 | 03:55 PM
thumper650's Avatar
i dont want to go to a turbo
Old Jan 27, 2005 | 04:39 PM
BillDS650's Avatar
you can just buy the EFI just call
Old Jan 27, 2005 | 04:40 PM
thumper650's Avatar
ya i called them
Old Jan 27, 2005 | 05:00 PM
JEFFROE's Avatar
ever get stuck in the same old rutt. i have had 3 different ds's that i put the 45mm mikuni's on. not sure why because none of them had an accel pump and would stumble off idle if you hit the throttle hard. if you get a new carb make sure it has a accel pump and soft spring for use with thumble throttle. my 2 cents
Old Jan 27, 2005 | 05:04 PM
thumper650's Avatar
thanks
