kn filter---- airbox or no airbox??
Old Jan 27, 2005 | 09:46 PM
LVSARGUY's Avatar
Default kn filter---- airbox or no airbox??
hey guys i want to say thanx for the replies in this forum , im glad i found this site..my question now,, i have 2003 ds racer kn filter with airbox and hmf slip on ..no revbox...i am wondering my freind lives in coos bay oregon and has a ds 2001 he bought the aftermarket carb i believe its an electron and revbox ron woods and put a kn filter directly on the carb mouth ,, now bear with me.. he says the electron carb will fit thekn filter becuase the angle is diffrent from stock, he says if you put the kn filter on a stock carb it will rub the bottom of the seat and rub a hole in the kn filter..and he said he did not see a big diffrence in power when using the slip on kn filter ...ok now he also says that the electron carb was hassle and put the stocker back on ...my question is going somewhere i promise..now here is what i want to do , buy the carb from my friend and put the kn filter on the mouth of the carb ,i need someone who has done this mabe give me some insight here on this , i dont want to throw money out the window ..oh and last but not least i need to buy a revbox ,, how much does this really help ??? i found 1 on alba action for 99.99 becuase mine is a 03 racer or i gota buy a 299.99 box .. any info would be great thanx rj
Old Jan 27, 2005 | 11:38 PM
sam's Avatar
sam
if you get the lectron leave the intake boot (between the carb and airbox) on and put a k-n on it . why? the tube gives it a ram air efect . you can take the airbox off though.
Sam
Old Jan 28, 2005 | 02:13 AM
StillRacinA250r's Avatar
Neither carb will work properly with a direct mounted filter. I'm a big fan of the lectron carb, just putting it on gives it huge gains. You will need to leave the stock intake boot and mount the k&n at the end of the boot as SAM stated. Wouldn't bother using the airbox unless you're going to going through alot of water & mud. Just make a bracket to hold your intake boot & filter. For more info on the lectron see hpresearch.net & talk to eric or randall - both very knowledgable.
Old Jan 28, 2005 | 11:09 AM
BillDS650's Avatar
leve it in the air box just up date the intake boot
Old Jan 30, 2005 | 01:52 PM
LVSARGUY's Avatar
how do i update the intake boot ??? rj
Old Jan 30, 2005 | 02:34 PM
blue250r's Avatar
Get one for an 04 or 05 from your dealer
Old Jan 31, 2005 | 12:32 PM
DuneMe's Avatar
I have run side by side direct mount air filter direct mount and in the box at about 4000' elevation and the difference was incredible!
I know there have been a lot of dyno runs and comparisons but, I just am having a tough time getting away from results I've seen first hand.
I haven't tried the new air intake so, maybe that's the key???
As for CDI's - First. . . remember the old rule. . . you get what you pay for!
Do a search for threads on CDI's - There is plenty already out there - no need to re-hash.
What kind of bike do you want to build? Don't expect a CDI and a carb to win the races. A good exhaust, CDI, and carb / air filter package should net you some really impressive HP gains but, a high compression piston and a set of more aggressive cams will allow you to blow the doors off you bolt-on buddies.
1986Vmax540
Jul 9, 2021 09:53 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Dammar
Aug 26, 2015 07:12 PM
ghost civic
Jul 20, 2015 12:36 PM
