Honda shifting weird
Old Jan 28, 2005 | 10:26 PM
charlieborg's Avatar
Default Honda shifting weird
I have a 2004 Honda rancher 400 at 4x4. Seems to not shift right. Starts out ok, but when you slow down to around 8 mph, and give it gas, it has no power, like it is slipping. You can slow down to almost stopping and hear it shift back into first, then it is ok. Is this normal? Does ok in electrical shift mode, just does this in auto.
Old Jan 28, 2005 | 11:32 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
This machine is famous for having no low end power!
Old Jan 28, 2005 | 11:49 PM
2TV's Avatar
2TV
Did you check your oil level? I have a friend with a Rubicon and sometimes it would exhibit this "slipping" sensation where it seemed like it was suddenly trying to pull a very heavy load. More throttle was applied and eventually it would get moving and seem normal again. However after that we discovered the machine was low on oil and this problem went away after it was topped off...
Old Jan 29, 2005 | 12:57 AM
BigReub's Avatar
Sounds to me like as long as you are still rolling the machine's not downshifting properly. I have never experienced this, but have read about it. Unfortunately I cannot find where I have read it or remember the reason for it.
Old Jan 31, 2005 | 12:06 PM
BigReub's Avatar
I found some info about this - I knew it was here somewhere.
ECM Recall
copy of Notice issued in USA
the Engine Control Module (ECM) - on affected units, the ecm that controls the transmission shift performance has a programming error that may affect proper transmission operation at low vehicle speeds. If the unit is slowed to below 5 mph, without coming to a complete stop, and throttle is re-applied, the transmission may not change over to a lower torque range. This strains the centrifugal clutch, potentially reducing it's service life.
Please contact your nearest authorized Honda ATV dealer and make an appointment to have the ecm replaced on your TRX400. Additionally, your ATV's centrifugal clutch may need to be inspected and serviced, depending on it's condition. The dealer will replace the ecm and any additional required parts at no cost to you for parts or labor. Please plan to leave your ATV at the dealership for at least one day to allow for the dealer scheduling.
This product update campaign ends on June 1, 2007. You must have your 2004 TRX400FA/FGA updated prior to this date.
If you have already had the ecm, centrifugal clutch, and/or related parts replaced, you may be eligible for reiembursement.
Aug 6, 2015 11:49 AM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
Scottma518
Jul 16, 2015 09:19 PM
