Grizzly, Kodiak, Bruin owners, Try this
Old Jan 29, 2005 | 09:40 AM
WolverineMan15666's Avatar
Default Grizzly, Kodiak, Bruin owners, Try this
First take the keys out of the ignition. Then, plug a rechargable spotlight or portable battery jumper into your ciggarette lighter outlet. Then, push the start button. What happens? Why does this happen only to Yamahas?
Old Jan 29, 2005 | 10:25 AM
Anyone ever try this?..................If you didn't know,......it starts. It starts without the keys even in the ignition. Try it on yours.
Old Jan 29, 2005 | 10:55 AM
05YK450's Avatar
On all years and models? I'll have to try my 05. All other functions must not work though.
Old Jan 29, 2005 | 11:04 AM
It works on my '04. I wondered if they fixed it. They should! When someone showed it to me I couldn't believe it. They started my Grizzly, when I had the keys in my hand, standing 10ft. away. They had a cordless spotlight with the battery ON it. The Grizzly must get juice from the spotlight battery somehow. If you unplug the spotlight while the quad is running the quad will shut off. I guess the theives already know this trick. We tried it on a Honda Rancher and it does not work on them.
Old Jan 29, 2005 | 08:07 PM
Anyone try this yet?
Old Jan 29, 2005 | 09:20 PM
goldmember's Avatar
Didn't work for me on my 05 Grizz.
Koko
Old Jan 30, 2005 | 01:15 AM
BruinBoy's Avatar
My '04 Bruin doesn't have an accessory outlet. That would suck though.
Old Jan 30, 2005 | 09:16 PM
Anyone else try it?
Old Jan 30, 2005 | 10:20 PM
hondabuster's Avatar
Seems to make sense, its really no different than just putting a jumper accross the two wires at the switch, except using an external battery, instead of the onboard battery. The system doesnt care where the 12 volts comes from , it just needs 12 volts on the brown/ blue wire, and thats whats happening.
I havent tried it on mine, but I believe you.
Old Jan 31, 2005 | 01:27 AM
mike7330's Avatar
If thats the case of the atv getting power from the external battery from say the light or whatever, it can be changed if you don't want that to happen. All you have to do is cut the outlet wire, and install a Diode, that way power can not go back into the system. I have an '04 Kodiak, I must try that, just see if it works.
