Primary spring change on 800, then 800 lost 40lbs!!
Old Jan 29, 2005 | 05:57 PM
GE4x4's Avatar
Default Primary spring change on 800, then 800 lost 40lbs!!
I did some spring swapping today, one was a Dalton blue and the other was a Dalton orange blue. The blue had a 3/155 stall and the orange was a 25/167. I believe the stock spring is around 0/122. I tried the orange first. The stall was about 300-400 rpms higher then stock, but it wasn't that bad. It took off great, but I was hitting the rev limiter very quick. I know I was getting a lot of wheel spin, plus being on snow didn't help either. Even in 4x4 I was hitting it quick. So under the conditions I could not really get a good feel for it. Then I put the blue in. The stall was just about 100 rpms higher, but you allmost didn't notice it. The take off was very simular to stock, but it felt like it just kept climbing, where as the stock one would flatten out after about 35. So in the conditions I was in, I liked the blue over the stock much better, so for now that will stay in. I will have to wait until dry ground to be able to test the orange.
Now the weight loss. Some things are just not neede for GNCC racing, and rack and storage is one of them. So I took my rear rack and storage box plus my front storage box off. I could not believe how much they weighed. The rear rack was 16-17lbs, the rear storage box came in at 6lbs, and the front came in at 17-18lbs. So about 40lbs was taken off. This should help a lot.
Old Jan 29, 2005 | 08:22 PM
ho500sportsman's Avatar
did you try any different exahausts or cutting the air box?
Old Jan 29, 2005 | 08:37 PM
SPORTSMAN70003's Avatar
Do you have any pics?
ho500sportsman, I sent you a PM.
Old Jan 29, 2005 | 09:40 PM
GE4x4's Avatar
I'm running the stock class so I can't do anything to the exhaust, airbox, or engine.
Old Jan 29, 2005 | 09:41 PM
GE4x4's Avatar
Not yet, I'm still waiting for a few things. I don't want to take pics until I'm done.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 29, 2005 | 09:44 PM
Keep us posted.
Old Jan 30, 2005 | 01:33 AM
TEXMud's Avatar
When you remove the front storage it will look like this:
http://www.ansley.net/images/sp800/2...61_(Small).JPG
and
http://www.ansley.net/images/sp800/2...62_(Small).JPG
Old Jan 30, 2005 | 01:57 AM
elkbow's Avatar
and
I had mine off when installing the winch, that sure is ugly....
Old Jan 30, 2005 | 02:26 AM
spyder6's Avatar
when installing the winch all you had to do was take the bumper off, btw, nice findings on the weight loss and clutch, i donno if you want to take the front bumper/lights off but if you do, there not really that heavy, like 5 pounds i think as its made of nano-fiber
Old Jan 30, 2005 | 02:42 AM
elkbow's Avatar
not if you do everything perfectly like me....I make sure all the cables are run right, tied up, and i label my wires....etc....
