trailblazer vs trailboss 325
Old Sep 17, 2000 | 06:29 PM
blasterguy's Avatar
which one is faster really like both which one is a better jumper.is eather one good in mud.
thanks
Old Sep 17, 2000 | 07:52 PM
2000Polaris's Avatar
The Trailblazer is faster and a better jumper. It's a little lighter than the Trailboss plus it's a 2-stroke. I'm not guessing at this because I used to own a 00 Trailblazer and a friend of mine has a 00 Trailboss. We raced many times with the same outcome. The Trailboss does jump good, it's just not quite as fun. As far as mudding goes, neither of us had problems in the shallow stuff, but when it came to the thick deep mud you need a 4x4.
Old Sep 17, 2000 | 10:52 PM
will's Avatar
I have had both if you want reliability go with the boss if you want a better jumper and more speed go with the blazer. You can also modify the 2 stroke alot cheaper
Old Sep 18, 2000 | 02:20 PM
96fmfblaster's Avatar
how much faster is the trail blazer over the trail boss.
Old Sep 18, 2000 | 03:18 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
It is ALOT faster.
Old Sep 18, 2000 | 03:35 PM
I wouldn't say it's alot faster stock vs. stock. Since the trailblazer is a 2-stroke, once it gets going, it really seems like you're going pretty fast, but in reality the top speed isn't that fast. The trailboss has more torque since it's a 4-stroke so it has a little better take off. It seems like every time I went up against the trailboss I would pull past it around the middle of the powerband. He would always get me at take-off. Hope this helps.
Old Sep 18, 2000 | 05:36 PM
nauvooguy's Avatar
Your Trail balzer has a powerband?
Old Sep 18, 2000 | 06:01 PM
SpankyCSW's Avatar
Do you know what a powerband is? All quads "have" powerbands. It's the word people use to describe the machine's horsepower output curve. Low end = early acceleration, Mid = the middle (duh), and Top End = approaching top speed and the peak of the power curve.
Old Sep 18, 2000 | 09:18 PM
will's Avatar
I had noth quads at the same time and my trailboss had a white primary spring to let it rev up a little more on take off for a better jump my dad on the trailblazer weighing about 40 pounds more and me on the boss and the blazer would beat it every time. Yes if you put a pipe on the blazer does have a power band
neo27ny
May 14, 2018 12:19 PM
Myronh
Sep 8, 2015 11:27 AM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
