Glacier Plow System
Old Feb 3, 2005 | 09:45 AM
Thevolkp's Avatar
Default Glacier Plow System
Hi:
Just bought a 2005 Sportsman 400 and want to install the Glacier Plow System on it. I'm leaning towards the 56" 2 Way Razor. Someone mentioned that this plow is actually 60" wide. Does anyone know this to be true? My trailer is 60" wide and a 60" wide blade won't fit between the sides of the trailer. I plan on using the plow for mainly plowing snow, but also plan on using it for light dirt/gravel leveling.
Thanks!
Old Feb 3, 2005 | 10:50 AM
silverbullet2005's Avatar
if you have a 60 inch plow you can still turn the plow blade angle so that is will fit into the trailer as long as you have a bit of extra space lengthwise. I have the glacier blade on my 700EFI and the plow works great, the only thing I don't like is that you have to get off the quad to change the angle of the blade but I read a post where someone was going to try to add the remote plow blade angle cable.
Old Feb 3, 2005 | 11:50 PM
Primus's Avatar
I have the Razor blade on mine and it's 60 inch wide but as silverbullet2005 said you can just angle it to fit in your trailer. I don't know if they come in different widths though because I thought I seen a brochure that said 56" Razor but when I ordered mine it was 60 and that's what it said on box.
Also Polaris has a handle that sticks up to angle it while seated, but it wouldn't be any good for me because of the fairing/windshield.
Old Feb 4, 2005 | 12:11 AM
BigRigIns's Avatar
i got a 5x8 trailor and i just angle the the blade and it works just fine . just barley but it works.as for silver bullet and geting off to angle your blade i was in the same boat, but what i did was take a couple of I bolts put em in the middle of the plow add some twine a couple of handles and wa la no more geting off the machine everything is done from the machine. works real nice[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 4, 2005 | 09:41 AM
jinks's Avatar
Yes, Razor blade sais 56" in book but in reality it measures 60" wide and when angled about 54" wide when measured perpendicular to the frame lengthwise.
Old Feb 4, 2005 | 10:12 AM
hey bigrig do ya have a picture of the setup?
Old Feb 4, 2005 | 10:26 AM
xcrider's Avatar
Do yourself a favor and before you install the mounting plate that hangs on the quad. drill a hole in the plate for the front diff drain plug. That way you will never have to take the plate off just to change the fron diff fluid.
shimanok2
Jan 29, 2016 07:37 PM
Oct 10, 2015 10:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
