Crank resolution answer for owners
Old Feb 7, 2005 | 09:59 PM
Sandgod's Avatar
Default Crank resolution answer for owners
I called Crank Works in Tempe AZ today.. I asked what they do. They will pull apart the old crank, install new Z400 bearing, press crank back together. They check the crank for balance while it's apart. I can't explain it as I am unsure. When it's together they will add weight if needed at 18cents a gram.. As much as 100 grams could be used or as little as zero.. They harmonically and dynamically balance them... You must send the piston on the rod w/ the circlips and rings. Every crank/piston set up will weigh different!!!!!!!!!!!!! The goal is to get them w/in two grams of perfect.. 135 bucks plus the cost of how many grams of material and you supply the Z400 big end rod bearing...
Old Mar 15, 2005 | 07:57 PM
GlamisRat's Avatar
have you had work done there before? im sending my crank to them tommorow. I talked to them and they said $180 and additinal $35 for the z400 bearing which they stock. They seemed to be very familiar with the cannondales. well see.
pgamboa
Dec 24, 2023 11:52 AM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
DM2015
Sep 7, 2015 10:36 AM
Jason Richards
Sep 4, 2015 06:17 PM
