Kill Switch
Old Feb 9, 2005 | 10:40 AM
heatseeker8's Avatar
Default Kill Switch
I have a Tusk off road tether kill swithch I just got. it has a black and a white wire..also no instructions..none.
I want to put it on my Predator..any idea where to start?
Old Feb 9, 2005 | 10:46 AM
quadsnsleds's Avatar
Default Kill Switch
Don't know for sure on the Predator, but when I had my 400ex I put a tether on it & same thing..... no instructions. What I did was traced the wires back from my kill switch on the bars to under the plastic where it was hidden, CAREFULLY razor bladed off the tape/wire coating, found the hot wire thru trial & error & then grounded the black wire. Hope this helps some, I'm sure Pred. owners will chime in here for further help.
Old Feb 9, 2005 | 12:54 PM
RAJ's Avatar
RAJ
Default Kill Switch
Go here and ask the question, if you have not already, they will help ya out.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 9, 2005 | 01:54 PM
cfscram's Avatar
Default Kill Switch
under the front plastic is a connector not hooked to anything if you get two spade tips for the wires on the kill switch you just plug one in to each side and then tape it up. the wires going into the connector is 2 brown and 2 black. they had it wired for a kill switch.
Old Feb 9, 2005 | 04:50 PM
tyler711's Avatar
Default Kill Switch
So I am assuming that with the kill switch attached (running) it is an open circuit, and when it is removed (engine cut) it closes the circuit? I would think it would be the other way around, so it could just open the ignition wire on a quad that was not pre-wired.
Tyler
Old Feb 9, 2005 | 05:19 PM
cfscram's Avatar
Default Kill Switch
no what you are doing is grounding the ignition and that is what kills it. the kill switch is open till you pull the clip then it closes and causes the ground.
Old Feb 10, 2005 | 12:28 PM
tyler711's Avatar
Default Kill Switch
Oh I see, thanks. Like the kill on my leaf blower, it has a pin that pokes throught the back of the spark plug's rubber cap and shorts it to the block.
Tyler
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
toonces
Sep 5, 2015 01:14 PM
