Rear Wheel bearing help
Old Feb 9, 2005 | 08:04 PM
Thumper33's Avatar
Default Rear Wheel bearing help
I have a rear wheel that wobbles quite a bit. I had a simillar problem on one of my trailer wheels and I could fix it by simply tightening the nut down farther that held in the bearing. What holds the bearing in? Is it just time to replace it? If so, can I just try replacing the bearing w/o the race first? I just don't want to have it torn apart in the garage for a week while I wait for parts.
Any advice is appreciated!
Thanks,
Mike
Old Feb 9, 2005 | 08:16 PM
jeffro206's Avatar
are you talking on sportsman? if so the rear bearing is a big ball bearing. all one piece. about $50 dealer. never looked at parts stors local. sure one would have it cheaper, if not you can order online.
Old Feb 10, 2005 | 12:14 PM
Thumper33's Avatar
ya, sorry. 96 sportsman 500. I see the newer models' kits for sale on ebay, but nothing for the 96.
Old Feb 10, 2005 | 08:32 PM
jeffro206's Avatar
thumper, the bearings are the same for some later models like 02 polaris pn 3585502
Old Feb 20, 2005 | 04:29 PM
floodrunner's Avatar
Jack your machine up and take the rear tire off to determine whether the looseness you’re experiencing is in the bearing that’s in the hub or the three suspension bushings that hub is attached to. I don’t know about a ’96 but later model Sportsmans have a big sealed bearing inside the hub, although it can come apart if half of it gets stuck on the CV stub axle when you’re removing it to replace a torn boot (ask me how I know). Replacing the bearing requires some pretty basic mechanical disassembly, then just heat up the hub to expand it and the bearing will fall out, at least mine did. If your bushings are worn replace the nylon and metal parts, again pretty basic mechanical skills and normal tools are all that’s required.
Ean
Dec 19, 2022 08:48 AM
greg74
Sep 10, 2019 03:03 PM
rcappie4
Jul 18, 2015 07:51 AM
Peter_
Jul 18, 2015 07:06 AM
rcappie4
Jul 10, 2015 04:54 PM
