mods on an explorer, i need opinions
Old Feb 9, 2005 | 11:19 PM
sirsinkalot's Avatar
Default mods on an explorer, i need opinions
i have a 2001 explorer 400, 38 tmx flatslide, v force reeds, air box mod, compression hole plugged, snorkled clutches, installing nitrous next week.
i'm thinking of a big bore,team roller or aeen roller. i ride in mud,skeg,rivers and mountains so i need my bottom end grunt and reliability.
any suggestions are apprieciated.
Old Feb 12, 2005 | 12:47 PM
ftwflh's Avatar
If you dont already have a pipe get you either a Dynoport or Aaen torquer they arte both low to mirange pipes. I hadnt noticed if you said you have rebuilt the topend?If not DO IT NOW before you break the stock junk piston.Then get the cylinder trail ported.As for the TEAM roller secondary they are great but if I were you I would port the engine first then get the roller.By the way both pipes I mentioned run close to the stock RPM range so you wont need to have a real high engagment speed. I had a 96 400 Sportsman setup alot like yours and with it ported and piped it would smoke the 660s and 700s.
Old Feb 12, 2005 | 11:44 PM
did you find you gained any bottom end or at least maintained it?
who done your porting for you ?
Old Feb 14, 2005 | 07:49 AM
ftwflh's Avatar
It made a huge improvment on the bottom.I did the porting to a guys specs for trailporting.But you will need a pipe and the right clutching.
Customer Service #1
May 15, 2020 08:46 AM
Robinhood
Dec 26, 2015 10:28 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
