Sway Bar Disconnect, What the F _ _ _ ?????
Old Feb 11, 2005 | 11:59 AM
FireCaptainSteve's Avatar
Default Sway Bar Disconnect, What the F _ _ _ ?????
I just purchased the sway bar disconect. I put it on last night. I STILL CANT GET IT ON AND OFF !!!!!!
Im finding it imposible to get back on. If its this HARD to do I may NEVER want to diconect in the woods!!!
HeLp !?!?!?!?!?!
Old Feb 11, 2005 | 12:04 PM
OK , an hour of busted knuckles and its on.
Bent clips , wd 40 and a hammer!!!
This is NOT user friendly.
Good Idea but needs alot of work to be perfected.
I will try to remove it and put it back on within 1 hour and get back to everyone.
Anyone else having problems with it ???
Old Feb 11, 2005 | 01:09 PM
SPORTSMAN70003's Avatar
I have never had that much trouble with mine it takes just a few minutes to take it off and put it back on.
Old Feb 11, 2005 | 01:20 PM
BlackRaptor's Avatar
What does disconecting of the swat bar do for you?
Old Feb 11, 2005 | 01:45 PM
20045SP500HO's Avatar
It may take a few times to break in the disconnect, just use a little lube as you did. I've also found with all the weight i've added to the rear of my sportsman it's harder to get on and off than when i first installed it, becuase of the sagging rear. But with all that said i ride now 99% of the time with in off and I LOVE IT! I keep the disconnect under the seat just in case we are going to be crusing for a while.
a few of things to remeber:
1. make sure the machine is on level ground when removing and installing.
2. put the bottom on first and slide the top over the square tube.
3. the square tube will move left (if looking from the rear), this helps during reinstallation, push it over if you can.
4. keep it clean ... any dirt will REALLY make it hard to put on.
5. get the weight off the rear of the machine ... the more weight the harder it is to get on.
** my in the field tip [img]i/expressions/face-icon-small-wink.gif[/img]
I use my rear winch and a tree to lift the rear just alittle off the ground to reinstall ... this makes a world of difference!
---look at my sportsman and you will see why---
---it's a little fat in the #$!---
Old Feb 11, 2005 | 02:25 PM
silverbullet2005's Avatar
where do buy the kit?
how much is the kit?
can the disconnect kit be put on a lifted quad?
Old Feb 11, 2005 | 03:17 PM
elkbow's Avatar
It takes alittle getting used to, to take it off and put it on, I can do it quickly now....
if you want one, get it from here:
disconnect
Old Feb 11, 2005 | 09:18 PM
yaK's Avatar
yaK
I really dont understand the advantage of disconecting this....plus it sounds like a pain in the @$$
Old Feb 11, 2005 | 10:52 PM
I will give it another try in the AM. I will also try to get someone to help lift the weight of the atv to assist.
If it takes someones help for me to get it on, then thats fine. I will only take it off if im riding with a friend or if Im going to stay under 30 MPH.
Vaquero's Avatar
I have had very good luck with the disconnects on my sportsmans. Being on level ground when you connect or disconnect the link is a big help. Disconnecting the sway bar really helps the ride and the independent suspenion travel, I also ride mostly with it disconnected unless on a logging road or smooth field. look at 20045SP500HO's pics. he has done a great job on his web page.
silverbullet2005 yes I have a friend that had one made special for his lifted quad, he has a highlifter 2" kit and it's OK.
20045SP500HO has some great tips also that make it a little easier.
