can one tire lean in more then the other?
Old Feb 12, 2005 | 12:16 AM
BigRigIns's Avatar
Default can one tire lean in more then the other?
im looking at my sp 600 and the left front rim looks like its leaning in,the right one looks straight,so i look in my mant man and it says no adjustment for the camber . so my question is is it possable for the the tires to lean in and is there any way to adjust them?
any advice would be great
thanks bigrigins
Old Feb 12, 2005 | 12:25 AM
Polaris500HO4x4's Avatar
there isnt any adjustment for the camber, polaris has a slight negative camber on all there machine for better handling in corners, if u turn your wheels left then right a few times it may go back to normal
Old Feb 12, 2005 | 12:28 AM
BigRigIns's Avatar
thanks
Old Feb 12, 2005 | 12:56 AM
elkbow's Avatar
Polaris500HO4x4 is right, there is no camber adjustment. If this is indeed the case with your machine, where the camber is off, then check for bent parts, etc.
Also, Toe is adjustable, look at the Owners manual, I believe the toe adjustment is in there using a string around the machine.
One thing that some people mistake is not putting the handlebars/tires pointing perfectly forward, if off slightly you will show a different camber from side-to-side.
Old Feb 12, 2005 | 02:29 PM
paulzaho's Avatar
Also make sure that your ball joints aren't worn.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
