Replace ball joint
Old Feb 12, 2005 | 06:47 PM
yunt2ride's Avatar
Default Replace ball joint
I have a 2000 model 325 magnum 4wd, I cannot get the ball joint housing out of the strut housing. Does anyone know how to do this. My ball joint wore out and I am trying to replace it. It looked pretty easy but now I am finding out that it is a job. Thanks ahead of time.
Old Feb 12, 2005 | 07:44 PM
BigBadScrambler's Avatar
When I did mine, I popped the ball joint off the a-arm and removed the backing plate. Then I put the nut back on somewhat loosely. I then used a torch to heat up the balljoint while at the same time useing a prybar on the a-arm to seperate the a-arm from the strut. Since the bolt is still on, it will pull the ball joint right out with it. When you go to put the new one back in. Put it in the freezer for awhile to get it really cold. If you get the strut hot it will also expand the opening. Then put a little silicone spray ont he ball joint and use a large socket to press it back in.
Old Feb 12, 2005 | 07:48 PM
thewayout420's Avatar
once you take the 2 screws that hold the retainer plate off,hook a slide hammer to the ball joint and it will pop right out,thats if you have a slide hammer..
Old Feb 12, 2005 | 07:52 PM
yunt2ride's Avatar
My ball fell out so there is no bolt to attach anything to. My A-ARM fell off.
Old Feb 12, 2005 | 08:01 PM
aww man,thats not good..not sure how you can get it now.
Old Feb 12, 2005 | 08:09 PM
yunt2ride's Avatar
I even tryed welding a bolt in the socket but it would not weld to the stainless.
Old Feb 13, 2005 | 08:37 AM
yunt2ride's Avatar
Anyone know how to get the housing out, the ball joint broke out of the housing and its the housing that I am having a problem with.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Dec 15, 2015 03:59 AM
toonces
Jul 28, 2015 01:58 PM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
