02 Scrambler X 400 Throttle problems
Old Feb 14, 2005 | 07:38 PM
treehugger's Avatar
Default 02 Scrambler X 400 Throttle problems
Hi. Just bought a scrambler X 400. Throttle seems to work fine until about mid range then dies right off, dosen't stall but dies off until Iback off the throttle again. Seems to do it mostly when it's cold and dosen't seem to havce the power it should. Helps when I pull the choke for a while. It sounds to me like it's running lean but not sure. Any ideas? Maybe float level. (anyone have the spec'c for the float?)
Thanks
Old Feb 14, 2005 | 11:01 PM
jeffro206's Avatar
could be something, dirt, water, etc.) in carb. could also be an air leak somewhere, like seal, gasket. try removing and cleaning carb first. dont forget to remove needle jet from center to be sure its open.
Old Feb 15, 2005 | 01:40 AM
fishslab's Avatar
Depending on how hard it was ridden a compression check may be in order.
Old Feb 15, 2005 | 01:17 PM
treehugger's Avatar
Thanks for your reply.
I don't think this machine has been rode much at all. It is still pretty tight all around. Even tighter than the 03 500 I bought. The throttle froze solid when I brought it home. Drove very cold weather for about 100 miles. Do you think it might have something to do with the ETC?
Thanks
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Ramman1
Jun 16, 2016 09:07 PM
Sjrpp
Jul 5, 2015 09:04 PM
