AWD always engaged
Old Feb 15, 2005 | 03:52 PM
tkc984's Avatar
Default AWD always engaged
I have a 2004.5 400 sportsman and noticed that the front wheels want to lock in with the AWD switch in the off position and the LCD display also indicates it is disengaged. I know the front wheels should engage when the AWD system is turned on, but only the back two wheels should spin when the system is off correct!! I have asked a few dealers what could cause this and I have gotten two replies. One stated it could be the armature in the front differential has became magnitised and the other stated there is an adjustment on the front differential that could correct this problem. I am hoping it is just an adjustment. If anyone knows anything concerning this problem or if anyone knows how to make this adjustment the advice would be greatly appriciated
Old Feb 15, 2005 | 04:05 PM
Zbart1's Avatar
Polaris is aware of this problem and is trying to figure out a fix
Since they changed the front set up it’s been a problem …..some real world dynamics working on the clutch in this set up……stay in contact with your dealer!
Old Feb 15, 2005 | 06:13 PM
tyler711's Avatar
I've spent so much time learning how the old outboard hubs work, I never took the time to look at my 04.5's center hubs. Is there one hub that engages both wheels, or do they still engage separately? I would imagine separately, but I've never gotten one side jammed in AWD on my 04.5 yet; my 250's do it all the time. Is the hub design still basically the same, or is it really changed?
TIA
Tyler
Old Feb 15, 2005 | 07:00 PM
tkc984's Avatar
I'm not sure how the old systems worked (this is my first). My 04.5 has a differential in the center, on the front of the atm and appears that it locks in both wheels. So to answer you question I believe it only has one hub to lock in both wheels. I've been told by a few dealers that there is an armature inside this diferential that will become magnitised if there is not enough oil in the differential causing the atm to stay in AWD at all times.
Old Feb 15, 2005 | 07:16 PM
tyler711's Avatar
That's what I figured. I'll look at an exploded view in the service manual. Its not a differential in the front though.
Actually, it must be two separate hubs, because with just one, it would have to lock the front axle AND engage the front wheels.
If you don't follow that^^, don't worry, I am thinking out loud....
Tyler
flyin-lowe
Dec 1, 2017 03:18 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
