banshee front end adjustment help
Old Feb 20, 2005 | 12:22 AM
mcgrogan's Avatar
Default banshee front end adjustment help
i had a head on the other day and bent my front rim badly. the wheel was bent outwards and i adjusted the steering rod to correct it but i am not sure if any other part is damaged , nothing looks bent or out of place. anyone have tips on what to look for and how to get the steering straight. cheers
Old Feb 24, 2005 | 07:31 PM
fastbanshee4u's Avatar
If you had to adjust your steering after the incident means something changed. Is tie rod end bent ,or could be spindle . I have done both in the past. Ratchet strap handle bars straight , then adjust front tires. Center of tires in front should be 1/4 inch less than back side of front tires. center to center across atv .Understand?
JackTheKing
Jul 14, 2015 09:09 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
jettman
Jul 6, 2015 12:16 PM
